ASA 5520 - VPN' tunel good unable to access inside
I just walked into this job to half way through a change over from a software firewall to the cisco box. The config on this thing is crazy. I need help!
I need to get a client VPN from outside to inside so the IT dept. can access the network hardware. then we'll add some static VPN's for other devices..
Anyway I've tried everything even the wizard on a dev box to figure out what is keeping me from accessing the network. I can establish a tunnel but can not get anywhere.
I've included the entire config as it's poor and the problem may be any place.
Thanks for any help.
