Test lab setup - need access to production network
Nov 16th, 2007
Hello there,
I am currently trying to set up a small test lab with which to test certain networking features and whatever else I need to test. I'd like to keep the test lab on a separate network and plus I need to be able to access the production network from the test lab -- with the goal being to analyze traffic coming from my machine while performing day-to-day tasks and manipulating the traffic without affecting the rest of the network.
Right now I have my laptop connected to a Cisco 1711 router. The router has a built-in switch. Here is the physical topology:
<laptop>--<1711 test router>--<2960xl production switch>--<3560G core switch>--<core router>--<ATM / MPLS WAN>
The ethernet interface of the 1711 is connected to the production switch. My laptop is connected to the built-in switch. My laptop is on a 192.168.1.0/24 network, the ethernet interface has an IP on the production network.
So far i'm able to access my local network. At first I was only able to access the local network if an entry in the test routers ARP table existed for that host. That problem disappeared after changing some settings. I wasn't able to completely solve the problem, but this morning the problem appeared to go away on its own.
The problem I have now is i'm unable to contact any remote networks on our WAN. Using static routes, i'm pretty sure both networks have routes going to each other (the test 1711 router can ping remote networks but the connected laptop can't)
Here is the config for the 1711.
version 12.3
service password-encryption
hostname ldntst1711
boot-start-marker
boot-end-marker
logging buffered 51200 critical
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
no ftp-server write-enable
no crypto isakmp enable
interface FastEthernet0
ip address <IP of production network> <subnet mask>
no ip proxy-arp
speed auto
full-duplex
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
no ip address
shutdown
interface Vlan1
ip broadcast-address 192.168.1.255
no ip proxy-arp
no ip route-cache cef
no ip route-cache
interface Async1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 <core router IP>
ip route <production network address> <subnet mask> <core router IP>
no ip http server
no ip http secure-server
control-plane
line con 0
password xxx
login
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login local
transport input telnet ssh
end
The routing table for my core router contains:
S 192.168.1.0/24 [1/0] via <test 1711 production IP>
The routing table for the remote network router contains:
S 192.168.1.0/24 [1/0] via <next hop for remote networks> (basically configured the same as our production subnets are in the routing table)
Any ideas or troubleshooting steps I can perform (debug commands, etc) would be greatly appreciated.
Nicholas Poole Fri, 11/16/2007 - 11:01
...S 192.168.1.0/24 [1/0] via
Is this the core, or another router which might need static routes adding?
Also, why have you got the broadcast address set, it really shouldnt need it.
bishop777 Fri, 11/16/2007 - 11:17
I'm not entirely sure, I think it may be the next hop on the MPLS network?
The WAN interface for the remote router with that route is x.x.1.1 and the next hop is x.x.1.2 ... all of the routes to the remote locations on that router use that as the next hop, though (it's on a different network than our production network is.) The remote router has a static route going to that network, using that address as the next hop. The core router has a route to 192.168.1.0 .
I've tried using the IP of the core router at my location, with the same result.
I can remove the broadcast address, I didn't think it was needed either, just added it as a troubleshooting step.
bishop777 Tue, 11/20/2007 - 10:51
Just an update on this - apparently the ISP won't allow all traffic across their WAN, we need to let them know in advance to allow certain networks to be allowed through. That's why this isn't working -- it's apparently blocked from their ATM switch or whatever the next hop is.
