%SYS-4-CHUNKMALLOCFAIL: Could not allocate chunks for ATM0/0/0
Nicholas Poole
I am having a problem with a 2811 that keeps getting this messsage:
Nov 16 18:34:58.645: %SYS-4-CHUNKMALLOCFAIL: Could not allocate chunks for ATM0/0/0
Total free: 0, Total inuse: 16, Cause : Not a dynamic chunk
-Process= "ATM Periodic", ipl= 4, pid= 80, -Traceback= 0x416A3DFC 0x400C3188 0x400C31EC 0x4037C4BC 0x400C5C1C
This causes the DSL interface to crash.
Sounds to me like a software caused memory issue, but I am at the top of my IOS release now and no improvement.
Has anyone seen this or got any sugestions?
7 Replies 7
cpartsenidis
I'm experiencing the same issue with a customer's 2811. Have you had any progress with the problem ?
paolo bevilacqua
Which exact IOS and DSL FW are you running?
The router is a 2811 running c2800nm-adventerprisek9-mz.124-15.T1.bin and has 256Mb Dram.
I've been advised to downgrade to 12.4.11T to see if it makes any difference.
Any suggestions ?
IOS should not make a difference.
What matters is that you upgrade the DSL FW, you can access at:
ftp://ftp.cisco.com/pub/access/800
The one you want is 3.0.x, there is a document describing how to install it.
Bevilacqua,
Here's the show dsl interface output. As you'll see, its already running firmware 3.0.014. Do you think I should still upgrade the firmware ?
ATM0/1/0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex B
ITU STD NUM: 0x03 0x2
Vendor ID: 'STMI' 'BDCM'
Vendor Specific: 0x0000 0x6110
Vendor Country: 0x0F 0xB5
Chip ID: C196 (0)
DFE BOM: DFE3.0 Annex B (2)
Capacity Used: 25% 31%
Noise Margin: 31.5 dB 27.0 dB
Output Power: 17.5 dBm 12.0 dBm
Attenuation: 18.0 dB 13.5 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0xE3
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00 (UR2)
Interrupts: 8254 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: OFF
LED On Time: 0
LED Off Time: 0
Init FW: init_AMR-3.0.014_no_bist.bin
Operation FW: AMR-3.0.014.bin
FW Source: embedded
FW Version: 3.0.14
Interleave Fast Interleave Fast
Speed (kbps): 0 2048 0 256
Cells: 0 297623 0 8495637
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 1
Header Errors: 0 0 0 0
Total BER: 0E-0 0E-0
Leakage Average BER: 0E-0 0E-0
Bitswap: enabled enabled
Bitswap success: 0 0
Bitswap failure: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
010: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
020: 0 4 4 4 5 5 5 5 4 4 4 4 4 4 4 4
030: 4 4 3 3 3 3 2 2 0 0 0 0 4 4 5 5
040: 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
050: 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 6
060: 0 2 5 5 5 5 6 5 5 5 5 5 6 5 5 5
070: 5 5 5 5 5 5 5 5 5 5 5 5 5 4 5 5
080: 5 4 4 5 5 4 4 5 5 4 4 5 5 4 4 4
090: 5 4 4 4 4 4 3 4 4 4 0 3 4 4 0 0
0A0: 4 4 0 0 0 4 0 0 0 4 0 0 0 4 0 0
0B0: 0 0 0 0 0 3 0 0 4 4 0 3 0 3 4 4
0C0: 0 3 4 3 0 3 4 0 0 3 4 0 0 0 0 0
0D0: 0 0 0 0 0 0 3 4 3 3 4 4 3 3 3 3
0E0: 4 3 4 3 3 0 0 0 3 3 3 3 3 3 3 0
0F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
ATM0/3/0
Line has not yet been activated.
Modem Status: Down (DMTDSL_DO_OPEN)
DSL Mode: Unknown
Interrupts: 659859 (0 spurious)
PHY Access Err: 0
Activations: 0
LED Status: OFF
LED On Time: 0
LED Off Time: 0
FW Source: embedded
yes to be on the safe side I would try first to upgrade to 3.0.33.
Failing that you may need help from the tac for further troubleshooting.
In the mean time I swapped my HWIC DSL for an old WIC which has resolved the issue. So i have looked at the firmware on this to compare it but its not the same chipset. Do you know where if this has new firmware and if so what the url is?
ATM0/0/0
Alcatel 20150 chipset information
DSL Mode: ITU G.992.1 (G.DMT) Annex A
