COR Blocking in CME
Nov 16th, 2007
Hello all
I'm messing around with COR for a customer and I'm having the following issue. I want to use COR to block 1900 calls but I'm noticing that it's behaving not the way I thought it should. I have the following setup and here is what is happening.
When dialing 91900XXXXXXX from ephone-dn 1 I'm noticing I'm getting my first match on Dial-peer 10 and the call is regected because this peer member is not in ephone-dn 1 corlist "BUT" i'm also getting a match on Dial-peer 8 which is less exact and the call is proceeding. Therefore if there is an overlap you COR doesn't work properly.
Yes I know I can use "after hours block 1 1900 7-24" under telephony services but this will block it for everyone. I want it to be flexible so that I can use COR to allow users to call 1900 if they needed to.
Thoughts?
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-ld
member internal
member local
member domestic
dial-peer voice 2 pots
description **Emergency Services 911**
destination-pattern 9911
port 0/1/0:23
forward-digits 3
dial-peer voice 3 pots
corlist outgoing call-local
description **For local 7 Digit calls**
destination-pattern 9[2-9]......
port 0/1/0:23
forward-digits 7
dial-peer voice 9 pots
corlist outgoing call-international
description **International LD calls**
destination-pattern 9011T
port 0/1/0:23
prefix 011
dial-peer voice 10 pots
corlist outgoing call-900
description **Toll Charge Calls**
destination-pattern 91900.......
port 0/1/0:23
forward-digits 11
dial-peer voice 11 pots
destination-pattern 91976.......
port 0/1/0:23
forward-digits 11
dial-peer voice 8 pots
corlist outgoing call-domestic
description **Domestic LD calls**
destination-pattern 91[2-9]………
port 0/1/0:23
forward-digits 11
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
load 7960-7940 P00308000400
load 7941 SCCP41.8-2-2SR1S
load 7961 SCCP41.8-2-2SR1S
load 7971 SCCP70.8-2-2SR1S
load 7970 SCCP70.8-2-2SR1S
load 7906 SCCP11.8-2-2SR1S
load 7911 SCCP11.8-2-2SR1S
max-ephones 36
max-dn 108
ip source-address 10.X.X.X port 2000
system message
time-zone 6
voicemail 2499
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name cmeadmin secret
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 2400 secondary 7807922400
label 2400
description Remote Site 1
name Remote Site 1
call-forward busy 2499
call-forward noan 2499 timeout 15
corlist incoming user-ld
corlist outgoing call-internal
ephone-dn 2 dual-line
number 2401 secondary 7807922401
label 2401
description Remote Site 2
name Remote Site 2
corlist incoming user-local
ephone 1
mac-address 001D.4561.5B98
username "user1" password 2400
type 7941
button 1:1
ephone 2
mac-address 001D.4543.A8FD
username "user2" password 2401
type 7941
button 1:2
Overall Rating: 5 (1 ratings)
vmilanov Fri, 11/16/2007 - 11:56
Hi Ryan,
First CME does not match peer on the 'most specific' basis, but rather it searches the list of configured dial-peers in the order they appeared in the configuration. So, when the dial-peer was rejected, the CME hunts for the next match.
Second thing, a cor list applied as 'incoming' to a phone-dn restricts where to this ephone-dn can dial-out. It has the same function as the Line CSS has in CCM. And a cor-list applied as 'outgoing' restricts which members can dial-in, and it behaves like the partitions in a CCM environment.
In your configuration the incoming cor-list of ephone-dn 1 has all the members but the '900' member, so this dn can dial out trough all the dial-peer except the dial-peer 10.
Respectively, ephone-dn can be reached by all the dial-peers that are members of the 'internal': in your case by all the dial-peers, because the pots ones do net have cor-list at all, so they have unrestricted access, and the ephone-dn 2 has a 'internal' membership via it's outgoing cor-list.
HTH.
Vasil
ryan_oconnell Fri, 11/16/2007 - 12:18
Ok,
Thanks for clarifing point one, about how dial-peer are matched in order vs most exact.
And your points on the Direction of COR and how it's applied I do understand. Or at least I think I do.
But my question is not answered.
At the end of the day, if I wanted to have a user that can dial 1900 as well as everything else but still restrict 1900 from the rest of the users how do I accomplish this?
In my example I'm trying to allow Ehpone 1 to dial "Domestic" but not 1900 numbers.
Thanks Ryan
Ryan
paolo bevilacqua Fri, 11/16/2007 - 12:21
  • Hall of Fame,
    Founding Member
Configure "huntstop" on the DP that are matching block.
vmilanov Sun, 11/18/2007 - 13:37
Hi Ryan,
I saw Paolo's reply and I find it very useful. I'll rate him.
So having in mind what he advised, and to have an easy to read and clean configuration, I would do the following:
-- copy all dial-peers config to a text file
-- delete all dial-peers from the config
-- re-order the dial-peers in the text file from the most restrictive to less restrictive ones, and then by most specific to less specific destination patterns.
-- add the 'hunstop' command to each one, except those used for local and emergency dialing.
-- re-assign the dial-peer numbers from top to bottom.
-- paste back the new dial-peers config to IOS.
With your config it would look this way:
dial-peer voice 1 pots
huntstop
port 0/1/0:23
forward-digits 11
huntstop
port 0/1/0:23
forward-digits 11
huntstop
port 0/1/0:23
prefix 011
dial-peer voice 4 pots
huntstop
port 0/1/0:23
forward-digits 11
dial-peer voice 5 pots
port 0/1/0:23
forward-digits 7
dial-peer voice 6 pots
port 0/1/0:23
forward-digits 3
Vasil
ryan_oconnell Sun, 11/18/2007 - 17:29
I did give his suggestion a try on Friday, just how you outlined and it did not work.
