Help needed with faulty Cisco 3000
Nov 16th, 2007
Hi All,
I have a old Cisco 3000 which I'm trying to get operational again, and also like to get advice on upgradeability. Any assistance would be appreciated.
It produces the following on bootup:
System Bootstrap, Version 4.6(1), SOFTWARE
Copyright (c) 1986-1992 by cisco Systems
IGS processor with 4096 Kbytes of memory
Flash: invalid chip id 0x9145 for flash
unable to configure flash for erase or write.
--- System Configuration Dialog ---
Refer to the 'Getting Started' Guide for additional help.
Default settings are in square brackets '[]'.
Configuring interface IP parameters for netbooting:
Configuring interface Ethernet0:
Is this interface in use? [yes]:
IP address for this interface:
Don't see any other details externally.
The motherboard ROMs show 9.1 3000-17131102 and 1202
