Ipphone develop environment + CallManager Simulator
Nov 16th, 2007
Im trying to setup an environment to develop ip phone software with no success for the moment.
My base platform:
. PC Windows XP SP2
. Installed Cisco Unified Application Environment
. Installed IP Phone SDK (comes with CallManager Simulator)
. Installed Cisco SoftPhone
. Installed VTGO ipphone (additionally to try, ipblue.com)
What i did:
. Login to CUAE see all is up
. Started CallManager Simulator (see no devices at a first glance).. Configured idle and services url to a valid address (tested on browser)
. Started Cisco SoftPhone.. Configured CTI Manager (on Settings/Advanced) to localhost:2000 where CM-Sim is listening.
I get no connection between the SoftPhone and CM-Sim. Same happens on VTGO and CM-Sim (if this useful to workaround).
I could verify that TFTP server on CM-Sim is working ok, since if a try to start another TFTP Service i get a port conflict (TCP 69).
What im doing wrong? misconfig?? Help very appreciated.
Diego
mohammednw Sat, 11/17/2007 - 22:59
hey man where do i get the simulator from... can u help me on this?
diegofabian1972 Sun, 11/18/2007 - 05:39
Hi Mohammed
You need to run CiscoIPPS_SDK_v4.1.1.exe .. This the installer for Cisco IP Phone Services SDK ver 4.1.1 . This installs severall development tools and source code (asp, jsp) for ip phone service development (pages that resolve via web a call that is made by an ip phone). With all this a call manager simulator version is installed. Check C:\CiscoIPServices\Tools\CallManagerSimulator to get call manager installation (if you run install to default dir).
If you make it work let me know :) .. i cant make a device be up on CM-Sim (call manager simulator).
Hope this helps
Diego
