11-16-2007 01:54 PM - edited 03-15-2019 07:17 AM
-CCME 4.1
-Analog trunks
Dial Peer for international dialing
dial-peer voice 314 pots
corlist outgoing long-distance
destination-pattern 9T
port 0/3/0
If you dial 9 or 9# and wait for the inter digit timeout. If you give you a second dial tone. From there you can dial anywhere.
How do I fix this? Thank you!
In addition, PRI does not have this problem. Only analog trunks
Solved! Go to Solution.
11-16-2007 03:38 PM
No bug.
destination-pattern 900[1-9]...T
prefix 00
replace 00 with your international access if different.
11-17-2007 02:04 AM
Yes, but the destination-pattern I suggested, is "better" because it enforces both pattern for country codes (none starts with 0) and a minimum number of digits to follow.
11-16-2007 03:38 PM
No bug.
prefix 00
11-16-2007 08:48 PM
From Canada, our international code is 011+
Can I do it like this?..
destination-pattern 9011T
prefix 011
Thanks Paolo!
11-17-2007 02:04 AM
11-17-2007 01:22 PM
I got you! Thanks again for all your help!
11-17-2007 02:57 PM
Thanks for the nice rating and good luck!
