paolo bevilacqua Fri, 11/16/2007 - 15:45
  • Hall of Fame,
    Founding Member
Yes, absolutely. The UC500 works fine as voice GW and/or SRST for a CM.
Q. Does the Cisco Unified Communications 500 Series support Survivable Remote Site Telephony (SRST)?
A. No, the Cisco Unified Communications 500 Series is a new platform designed for small businesses and supports standalone deployments. Cisco offers the integrated services router portfolio for deployments requiring interoperability with Cisco Unified Communications Manager and/or SRST functions. The Cisco Unified Communications 500 Series is meant for distributed voice deployments.
Q. Can the Cisco Unified Communications 500 Series be networked with Cisco Unified CME or Cisco Unified Communications Manager?
A. The Cisco Unified Communications 500 Series can be networked with an integrated services router-based Cisco Unified CME, but the Cisco Unified Communications 500 Series does not work with Cisco Unified Communications Manager.
AJAZ NAWAZ Sat, 11/17/2007 - 00:28
  • Silver, 250 points or more
Paolo,
Is there any specific feature set required for SRST/GW support that you stated?
tia
Ajaz
paolo bevilacqua Sat, 11/17/2007 - 01:56
  • Hall of Fame,
    Founding Member
Thanks cmonks, I stand corrected. I made confusion with the new 1861 that indeed supports SRST:
http://cisco.com/en/US/products/ps5853/products_qanda_item0900aecd806c4def.shtml
With regard to the UC500 however, beside SRTS that is not suppoerted as noted, it should work as H.323 or SIP GW for CM.
