Power Supply
Nov 16th, 2007
I've done a fair amount of googling, searching the IronPort KB as well as these forums and have not found a specific Voltage setting for powering the C150's. I've found references to Amp draw at different loads as well as an older document for a C10 saying something to the effect of 'anything from 110 to 240'.
Are the power supplies that versitle? Would you get more life out of a power supply running it at a specific Voltage rather than at some other hypothetical voltage?
Thanks Gang,
The LMT
Donald Nash Tue, 11/20/2007 - 16:37
I don't have any specific knowledge about the power supplies in a C150, but most modern power supplies are auto-ranging. If the C150 documentation doesn't mention input voltage, then don't worry about it. It'll work equally well anywhere in the 110 - 240 range.
