CCNA question
Nov 16th, 2007
Hi Gures' I am new to Networking field. Need help on topic. If I want to connect two hubs together, which cable 1.straight through 2.cross , is used? I mean what is the rule for connecting a pc to a hub or switch, or switch with switch? Sorry for silly question????Thanks for reply...
Overall Rating: 4.5 (4 ratings)
vgruiavgruia Sat, 11/17/2007 - 17:58
Since a hub is a stupid device, it has no switching/routing intelligence, the question is what are you connecting to the other end of the two hubs? the hub is just a continuation of what you are starting. ex: 1 pc at the end of one hub, another at the other end of hub 2. in this case you will need a cross over. make sense?
ellis_b Sat, 11/17/2007 - 21:54
it's not a silly question at all.
for two hubs, use a xover
for a hub to a switch, use a xover
for a switch to a switch, use a xover
for a pc to a switch, use a straight through
for a pc to a hub, use a straight through
for a pc to a pc, use a xover.
that being said, some of the newer cisco switches will auto-detect and take care of the xover for you if you use a straight through cable.
thanks,
Brad Ellis
CCIE#5796 (R&S / Security)
CCSI# 30482
CEO / President
CCBOOTCAMP - A Cisco Sponsored Organization (SO)
Email: brad AT ccbootcamp.com
Toll Free: 877-654-2243
Direct: +1-702-968-5100 = Outside the USA
FAX: +1-702-446-8012
YES! We take Cisco Learning Credits!
Training And Remote Racks: http://www.ccbootcamp.com
tahir1234 Sun, 11/18/2007 - 09:04
Thanks ellis. Once again, mean that I should remember this stuff and will have to check which device is going with which, or we can make a general rule for this? thanks for reply.
tahir1234 Sun, 11/18/2007 - 09:06
Ellis You did mention about what cable we will use from a pc to router ethernet , means xover or straight....thanks
LordFlasheart Sun, 11/18/2007 - 10:33
I like to remember the connections as points on a compass.
Host (PC) = North
Switch = East
Router = South
Hub = West
If you connect North to East, East to South, South to West, and West to North that gives you straight-through cabling.
If you connect North to South, and East to West, thereby CROSSING the centre they are your crossover cablings. Then all you need to remember is if it is like-for-like (i.e. router to router, switch to switch etc, it is a crossover cable).
HTH,
Chris
