IPCC Agent install Administrator, Supervisor and Desktop
Nov 17th, 2007
I cannot install the Agents no matter what. I had IE7 a removed it and still fails
Install Manager is unable to download the file
http://10.11.146.12:6393/TUP/CAD/InstallMgr/InstallManager.cfg
Any help would be appreiacted.
I can download the files.
But they do not install.
Raj
smalkeric Thu, 11/22/2007 - 10:34
  • Silver, 250 points or more
Do you have any firewall services running on the pc? try disabling it and againg try to install the Agent
sandeepkaran Fri, 11/23/2007 - 03:25
Check also whether you have admin rights t install the agent software or try to install it from the local admin or domain admin account
rshoker99 Fri, 11/23/2007 - 06:30
I ahve all the rights. I am able to download the agents. I am local admin on th maachine. The problem seems to be with the Ip address seems to be off. During install I get 10.1.146.12 should be 10.11.146.12
Raj
