Router 3825 Voice BRI interface don't work
alfbrt2133
hi.
i configure a BRI interface for Voice IP.
Everythin is ok, bet the ISDN interface BRI 0/0/0 no work correctly.
in debug i can see.
Layer 2 for interface BR0/0/0 TEI 82 change to up.
In 1 second.
Layer 2 for interface BR0/0/0 TEI 82 change to down.
In 2 seconds
and now again ....
can help me.
Alfonso
10 Replies 10
paolo bevilacqua
Hola,
do you ave configured clocks correctly ?
network-clock-participate wic 0
network-clock-select bri 0/0 1
also please try:
int bri 0/0
isdn tei-negotiation preserve.
If still issues please send output of "debug isdn q921" takeb with "term mon".
hope this helps, please rate post if it does!
Hola Paolo
i modify the configuration with this parameters but the BRI is equal.
i copy you the debug q921 and q931
016346: Nov 17 11:19:23.182 PCTime: ISDN BR0/0/0 Q921: User TX -> INFO sapi=0 tei=65, ns=0 nr=0
016347: Nov 17 11:19:23.182 PCTime: ISDN BR0/0/0 Q931: RESTART pd = 8 callref = 0x00
Channel ID i = 0x89
Restart Indicator i = 0x80
016348: Nov 17 11:19:23.198 PCTime: ISDN BR0/0/0 Q921: User RX <- RR sapi=0 tei=65 nr=1
016349: Nov 17 11:19:23.674 PCTime: ISDN BR0/0/0 Q921: User TX -> INFO sapi=0 tei=65, ns=1 nr=0
016350: Nov 17 11:19:23.674 PCTime: ISDN BR0/0/0 Q931: RESTART pd = 8 callref = 0x00
Channel ID i = 0x8A
016351: Nov 17 11:19:23.694 PCTime: ISDN BR0/0/0 Q921: User RX <- RR sapi=0 tei=65 nr=2
016352: Nov 17 11:19:33.690 PCTime: ISDN BR0/0/0 Q921: User RX <- RRp sapi=0 tei=65 nr=2
016353: Nov 17 11:19:33.694 PCTime: ISDN BR0/0/0 Q921: User TX -> RRf sapi=0 tei=65 nr=0
016354: Nov 17 11:19:34.142 PCTime: ISDN BR0/0/0 Q921: User RX <- DISCp sapi=0 tei=65
016355: Nov 17 11:19:34.142 PCTime: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 65 changed to down
016356: Nov 17 11:19:34.142 PCTime: ISDN BR0/0/0 Q921: User TX -> UAf sapi=0 tei=65
016357: Nov 17 11:19:34.146 PCTime: ISDN BR0/0/0 Q921: L2_EstablishDataLink: sending SABME
016358: Nov 17 11:19:34.146 PCTime: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=65
016359: Nov 17 11:19:34.158 PCTime: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=65
016360: Nov 17 11:19:34.158 PCTime: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 65 changed to up
016361: Nov 17 11:19:38.178 PCTime: ISDN BR0/0/0 Q921: User TX -> INFO sapi=0 tei=65, ns=0 nr=0
016362: Nov 17 11:19:38.178 PCTime: ISDN BR0/0/0 Q931: RESTART pd = 8 callref = 0x00
Channel ID i = 0x89
016363: Nov 17 11:19:38.194 PCTime: ISDN BR0/0/0 Q921: User RX <- RR sapi=0 tei=65 nr=1
016364: Nov 17 11:19:38.682 PCTime: ISDN BR0/0/0 Q921: User TX -> INFO sapi=0 tei=65, ns=1 nr=0
016365: Nov 17 11:19:38.682 PCTime: ISDN BR0/0/0 Q931: RESTART pd = 8 callref = 0x00
Channel ID i = 0x8A
016366: Nov 17 11:19:38.698 PCTime: ISDN BR0/0/0 Q921: User RX <- RR sapi=0 tei=65 nr=2
016367: Nov 17 11:19:48.698 PCTime: ISDN BR0/0/0 Q921: User TX -> RRp sapi=0 tei=65 nr=0
016368: Nov 17 11:19:48.698 PCTime: ISDN BR0/0/0 Q921: User RX <- RRp sapi=0 tei=65 nr=2
016369: Nov 17 11:19:48.698 PCTime: ISDN BR0/0/0 Q921: User TX -> RRf sapi=0 tei=65 nr=0
016370: Nov 17 11:19:48.710 PCTime: ISDN BR0/0/0 Q921: User RX <- RRf sapi=0 tei=65 nr=2
016371: Nov 17 11:19:49.150 PCTime: ISDN BR0/0/0 Q921: User RX <- DISCp sapi=0 tei=65
016372: Nov 17 11:19:49.150 PCTime: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 65 changed to down
016373: Nov 17 11:19:49.150 PCTime: ISDN BR0/0/0 Q921: User TX -> UAf sapi=0 tei=65
016374: Nov 17 11:19:49.154 PCTime: ISDN BR0/0/0 Q921: L2_EstablishDataLink: sending SABME
016375: Nov 17 11:19:49.154 PCTime: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=65
016376: Nov 17 11:19:49.166 PCTime: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=65
016377: Nov 17 11:19:49.166 PCTime: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 65 changed to up
wait your notices.
Alfonso
Please post the BRI interface config just here. And also output from show isdn status.
tia
Ajaz
Hi.
the information.
Current configuration : 269 bytes
interface BRI0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
end
MUTILVACISCO3825#show isd statusd
Global ISDN Switchtype = basic-net3
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN BRI0/0/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 65, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
Alfonso
the switch is bringing down L2, but strngely not L1 as well. You can try making and receiving calls anyway.
I would report it as incorrectly activated due to the reason above.
but,
i can't do any call.
no incoming and outcoming call's work.
Alfonso
Just report faulty circuit then. It's behaving strangely and cannot be used.
Good luck!
hi Paolo
thanks for your reply.
when i do show ccm-manager i see this.
MUTILVACISCO3825#show ccm-manager
MGCP Domain Name: MUTILVACISCO3825.grupopanasa.com
Priority Status Host
Primary Registered CALLMANAGER01 (xxx.xx.xx.xx)
First Backup None
Second Backup None
Current active Call Manager: xxx.xx.xx.xx
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 12:07:15 PCTime Nov 17 2007 (elapsed time: 00:00:03)
Last MGCP traffic time: 12:07:15 PCTime Nov 17 2007 (elapsed time: 00:00:03)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
--More-- Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: xx.xx.xxx.xx
Current Link State: OPEN
Statistics:
Packets recvd: 2989
Recv failures: 0
Packets xmitted: 2726
Xmit failures: 0
BRI Ports being backhauled:
Slot 0, VIC 0, port 1
Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: {84423BF3-AFC0-4A37-A9C7-781EA4C959F5}
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 18
Download Successful : 16
Download Failed : 0
Configuration Attempted : 10
--More-- Configuration Successful : 10
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: Reset
Configuration Error History:
voice-port 0/0/1no caller-id enable
voice-port 0/0/0no caller-id enable
voice-port 0/1/1no caller-id enable
voice-port 0/1/0no caller-id enable
FAX mode: cisco
MUTILVACISCO3825#
this "voice-port 0/0/1no caller-id enable" is a problem ???
why ??
regards again.
Alfonso
No sure, but it seems a bug in CM.
It tries to configure two commands on a single line, beside "caller-id" is not an option for BRI.
thanks for all.
i write two new post about this problem.
i think the problem is not call manager...
if you can read the other 2 post and answer me....
thank you very much.
