reg:cisco catlyst 4503
Nov 17th, 2007
Dear sir,
Iam having cisco cat lyst 4503 switch chasis with 3 slots
my doubt is this switch is comes under catagiry L4 or L3
and 3560 also l3 or l4
plz give reply
regards
srini
jlhainy Sat, 11/17/2007 - 12:42
That would depend on what supervisor model you place in the chassis. If you have a supe IV or higher, you will have plenty of routing abilities L3 and L4. If you use a supe II, then you will have basic routing abilities in static routes and maybe RIP.
