NEED HELP WITH CISCO 1601
Nov 17th, 2007
Dear Sir,
good day , i have a Cisco router model 1601 and i forget my enable secret
when i login with consol to reset the password and i follow all steps you mention in your support web site and type reset at end of steps to reload again and access my router
i suddenly found my router do not reponds to consol or evern ping or telnet
my router is ON and system LED is working ( OK ) but no responds to any thing
plz advice how to solve this problem and why it happen
appreciated send your reply soon for so urgent
regards
Mourad Aziz
ohassairi Sat, 11/17/2007 - 22:44
may be you changed the console rate from 9600 to other settings. try to modofy console speed, parity,...
try also to connect a sniffer to ethernet port and capture packets coming from router may be this will guide you and give you more idea.
