question from yesterday with more details
miloshbobic
yesterday I posted a question:
hello,
I have a question on how to configure that the same call goes and gets back over the same B (bearer) chanell in dial-peer pots configuration and what the configuration steps to achieve this would be?
you replied that it isn't possible and asked me to tell you what do I need it for.
Well I've been asked too and today got an explanation what was the intention. So here it is:
customer should do bit error rate test with local telecom. Local telecom is looking for the following:
1. telecom calling some number
2. customer Cisco AS5350 should send back that call via same channel, not via new channel
this is from Telecom tests table:
BER test (preferable 1 hour) according to G.821 parameters (loop back on BRA).
Thank you very much and sorry for bothering
Have a nice day
paolo bevilacqua
unfortunately I think this is not possible. Have you contacted your cisco office ? Perhaps they can check with engineering if there is a way they can provide a command to enable B-channel loopback in order to pass B-channel loopback test.
However, the whole controller can be put in loopback and this is enough for an accurate BER test.
thanks!!
