Kevin Dorrell Sat, 11/17/2007 - 10:33
I don't think there is any limitation, apart from the obvious 255 (or should it be 256?) on each VLAN. (In case you didn't know already, the HSRP groups are independent in each VLAN, so you can re-use the numbers.)
Kevin Dorrell
Luxembourg
