Updating CCM line name info from database
Nov 17th, 2007
I have a client that has a CCM 4.2, and they have many people that stops and starts in the company. I will like to know if there is anyone that know a good way to update the names on the phones in CCM from a external database.
eg. import line names etc on CCM from a sql database or other extarnal sources.
Soren
Overall Rating: 5 (2 ratings)
gogasca Sun, 11/18/2007 - 00:25
Not TAC Supported...!
The bug ID is:
CSCeg27782 - Bulk update line BAT does not support for 'Line Text Label'
We
already have a enhancement request.
As a workaround you need to update the field manually or run SQL queries:
To display the current fields use SQL Query Analizer:
select DNorPattern,Label from NumPlan,DeviceNumPlanMAp
where DeviceNumPlanMap.fkNumPlan = NumPlan.Pkid and Label IS NOT NULL
Note: The FkNumPlan will map this record to NumPlan table which contains the
Directory Number in question.
To Update the fields use for example:
update devicenumplanmap
set devicenumplanmap.label = ''
from devicenumplanmap
This will set the Line Text Label to blank, but it is needed to reset the
CCM service for both/all server in order to changes take place at IP phones.
Note: Resetting the CCM service will cause all your phones to go
unregistered and register back.
You can create your SQL query now that you know the fields accordingly.
What you need to do is create a TXT file then insert it into a new table in
CCMXXX DB what I did was create a Table called BAT (Have a good backup
before doing this)
and a file which contains the following:
"3001","Manager"
"3002","Assistant"
"3003","Employee"
(Quotes are only for being recognized as separated fileds in Export Data
Tool)
Insert it using Import and Export Data Tool under SQL Tools (Which also
creates the Table automatically for you).
Once the table is inserted it contains 2 columns Col001 and Col002
Table BAT
Col001 Col002
3001 Manager
3002 Assistant
3003 Employee
I run the following query and voila:
update DeviceNumPlanMap
set Label = (select Col002 from BAT,NumPlan where DNorPattern = Col001 and
DeviceNumPlanMap.fkNumPlan = NumPlan.Pkid);
Hope this helps.
Note again that this is NOT TAC Supported and is a BAT limitation.
