[OSPF]Any preference for higher cost Intra-Area route over Inter-Area route
akhran1974
If there is a intra-area route to a network that cost more than the inter-area route, is there a preference to choose the higher cost intra-area route over the lower cost inter-area route?
Eg.
Router1(f0/1)-----Area 1-------(f0/0)Router3
|(f0/0)
|Area 1
|(f0/0)
Router2(f0/1)-----Area 2------(f0/1)Router3
* The Router3 shown above refers to the same router.
Router1 f0/0 and f0/1 are in Area 1.
Router2 f0/0 is in Area 1.
Router2 f0/1 is in Area 2.
Router3 f0/0 is in Area 1.
Router3 f0/1 is in Area 2.
From Router2, to reach f0/0 (Area 1) of Router3, the route will go from Router2->Router1->Router3. Why doesn't it take the shorter path from Router2 to Router3? Is it because the longer route is in the same area and hence is preferred over the shorter inter-area route?
Thanks.
bvsnarayana03
Level 5
Level 5
In case of OSPF routes, the order of
preference is: (highest to lowest)
Intra area
Inter area
External route type 1 (E1)
External route type 2 (E2)
Within a single ospf process, u cant force the routes to change their preference. This may be possible for routes from different ospf processes.
pls rate if helped.
JORGE RODRIGUEZ
Level 10
Level 10
David, not expert in OSPF but there is rule described in RFC-2328 for OSPF route preference, bellow is the order, Intra-area routers are preference over interarea routes
1-intra-area routes, O
2-interarea routes, O IA
3-external routes type 1, O E1
4-external routes type 2, O E2
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a0080094704.shtml#q13
jorge
Jorge Rodriguez
