Putty not capable to show run ( pix)
iqbalkhan
I am using putyy 0.60.0.0. I have two pix firewall . When I am using putty to see the configuration of firewall the one of the firewall sh run is good work and i show see step by step but another firewall when i access by putty then i generate command sh run then configuration just comes at the end. i can not see full configuration..
So what is the problem ?. it is problem in my firewall ?.
biplob
ajagadee
Maybe one of the pix is configured with a "Pager x" command. The default for pager commands is 24 lines and this can be changed. If you have one of the pix configured for "pager 0", then you will see only the end when you do a "show run". If you have pix version earlier than 7.0, then this command is in enable mode. For versions higher than 7.0, the command is in config mode.
Please refer the below URL for details.
http://www.cisco.com/en/US/docs/security/asa/asa71/command/reference/p_711.html
Let me know if it helps.
Arul
** Please rate helpful posts **
