watchlist on - where'd it go!?
(Cisco Controller) >show watchlist
Incorrect usage. Use the '?' or <TAB> key to list commands.
(Cisco Controller) >config watchlist enable
I can't find any references that this feature set might have been discontinued, and it still appears in the command reference guide.
A command listing on the controller gives:
(Cisco Controller) >config ?
802.11a Configures 802.11a parameters.
802.11b Configures 802.11b parameters.
802.11h Configures 802.11h parameters
sysname Configures the system name.
tacacs Configures TACACS+ Servers.
time Configures system time or servers.
trapflags Enable or Disable trap flags that apply to the switch.
wlan Configures the Wireless LAN Network.
wps Configures WPS settings.
Trending Topics - Security & Network
