Cisco 6509 Catalyst Switch
Nov 18th, 2007
Catalyst 6509 IOS 12.2 (18)
Upgraded our Core Switch Last Night from COS to IOS. In the process we installed new blades. (6748-10/100/1000). We were only able to install the new blades into Slot 6 along with the new Sup 720 in Slot 5. The Switch would not recognized the new blades in any other slot, but Slot 6. Although we installed a new Gig-E blade 6724 into Slot 2. Any Ideas
Overall Rating: 5 (1 ratings)
balajitvk Sun, 11/18/2007 - 06:24
  • Silver, 250 points or more
I don't see any such restriction for 6748 interface modules on Cisco 6509.....
What error your getting while installing in other slot positions???
Rgs.
Edison Ortiz Sun, 11/18/2007 - 06:41
  • Hall of Fame,
    Founding Member
It sounds like you are exceeding your power requirements. Slot 5 and 6 have reserved power allocated even if you don't insert a Supervisor module in them, that's the reason the 6748 works there.
What model of power supply you are using ?
How many linecards and supervisor modules ?
Please post their complete model number.
FYI, the 6748 consumes 7 Amps while the 6724 consumes 2.23 Amps.
http://www.cisco.com/go/powercalculator
jpannorfi Sun, 11/18/2007 - 07:28
Posystem power redundancy mode = redundant
system power total = 1153.32 Watts (27.46 Amps @ 42V)
system power used = 1033.20 Watts (24.60 Amps @ 42V)
system power available = 120.12 Watts ( 2.86 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-2500W 1153.32 27.46 OK OK on
2 WS-CAC-2500W 1153.32 27.46 OK OK on
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
2 WS-X6724-SFP 125.16 2.98 125.16 2.98 on on
3 WS-X6316-GE-TX 216.30 5.15 216.30 5.15 on on
4 WS-X6408A-GBIC 84.00 2.00 84.00 2.00 on on
5 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
6 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
CRSW1>wer Status:
Edison Ortiz Sun, 11/18/2007 - 10:40
  • Hall of Fame,
    Founding Member
Yes, you don't have enough power.
As I stated before, module 5 and 6 have pre-allocated power even if you don't have any module inserted.
As you see you have 2.86 Amps left and 6748 requires 7 Amps.
You need to upgrade your power supplies.
