sunnyverghese Sun, 11/18/2007 - 22:41
hi Rob
i am facing an issue with the call forwarding
for ccme 4.1 as you said i tried to add teh command and i am getting the error
my intention is to transfer the incoming call to other numbers which command i need to use for a normal call transfer .
CCME(config-telephony)#transfer-pattern blind
Invalid character in number string Blind
sunnyverghese Sun, 11/18/2007 - 23:52
hi Rob
for ccme 4.1 as you said i tried to add the command and i am getting the error
Then i use the transfer-system full-consult
supplementry-service h450.2
and applied to the dial peer too
but i cannot hear you .
Rob Huffman Mon, 11/19/2007 - 08:14
Hi Sunny,
Try this instead;
transfer-system blind or full-blind
To specify the call transfer method to be used by Cisco Unified IP phones in Cisco Unified CME, use the transfer-system command in telephony-service configuration mode. To disable the call transfer method, use the no form of this command.
transfer-system {blind | full-blind | full-consult [dss] | local-consult}
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1084962
If you are using Transfer System Full-Consult then the ephones would need to be setup with a Dual Line config;
A dual-line ephone-dn has one virtual voice port and two channels to handle two independent calls. This capacity allows call waiting, call transfer, and conference functions within a single ephone-dn. Dual-line mode is supported on all phone types, but is not appropriate for voice-mail numbers, intercoms, or ephone-dns used for message-waiting indicators, paging, loopback, or hunt groups. Overlays of single-line hunt groups onto dual-line buttons are supported.
Ephone-dns are created in single-line mode if the dual-line keyword is not used. Changing an ephone-dn from dual-line mode to single-line mode (and vice versa) requires that you delete the ephone-dn and then recreate it.
Examples
The following example enters ephone-dn configuration mode to create the ephone-dn 5576:
Router(config)# ephone-dn 1
Router(config-ephone-dn)# number 5576
Router(config-ephone-dn)# exit
The following example creates an ephone-dn with the number 1001 in dual-line mode. The no huntstop command allows calls to continue to hunt to other ephone-dns if this one is busy or does not answer. The huntstop channel command disables call hunting to the second channel of this ephone-dn if the first channel is busy or does not answer.
Router(config)# ephone-dn 10 dual-line
Router(config-ephone-dn)# number 1001
Router(config-ephone-dn)# no huntstop
Router(config-ephone-dn)# huntstop channel
From this good CME doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611350.html
Hope this helps!
Rob
