Can't access remote resource in ASA VPN
Nov 18th, 2007
I created a VPN on ASA5510. I can establish the VPN, but can't access any resources. Also I can't access the Internet after establish the VPN. Any suggestions?
The configuration can be found this link:
ajagadee Sun, 11/18/2007 - 09:52
If you are able to connect and not able to access-resources, check for
NAT 0 - configured to bypass NAT for VPN Clients
Access-lists - Applied on the inside or DMZ
Routing - Make sure that the LAN inside the ASA knows where to route the traffic for the pool of IP Addresses assigned to the clients.
For Internet connectivity after VPNed into the ASA, You have two options
Split Tunneling or Permit Same-interface
** Please rate helpful posts **
