PGW2200 has a command PGW2200 has a command PGW2200 has a command
Nov 18th, 2007
do PGW2200 has a command to show the running configuration?
show ruu.
i need to see all configuration at my PGW.
tareqrebhi Mon, 11/26/2007 - 03:00
i have other question.
i have now 2 E1 connected to my Cisco AS5400 and i need add new E1. No problem with configuration at AS BUT my problem with PGW2200 it is live and provide the system with services.
i scared to work with PGW at live mode...i heared to add any service at PGW i must remove all configuration then add it again with new services i need.
my question do i need to remove all configuration and add new E1 then configure the PGW again with new updates?
if yes can advice me with steps to re-configure PGW?
if you need to see configuration file i have or any resources i don't have any problem.
thank for any help.
scpage Mon, 12/03/2007 - 13:44
No, you do not have to remove all config and readd it.
If you need to add a new E1 to an existing NAS to an existing dpc, just start a provisioning session and add the nailedtrnks...
If you would like to skip timeslot 16 for e1, you can break it up into 2 commands:
tareqrebhi Tue, 01/08/2008 - 10:17
can give me more help... i need to give you my all configuration for PGW and if you can make notes above the new commands i need to use... this because any error from me will make the service down.
after you give me the notes i will study it more before apply it.
any way thank you.
scpage Tue, 01/08/2008 - 11:46
Can you please attach your existing config along with details on what you would like to add. Also attach the sh run from the NAS and specify which e1(s) on the NAS you would like to add.
tareqrebhi Wed, 01/09/2008 - 08:07
OK I think my PGW has nailed configuration I have this:
is it true?
Now I need to configure the new E1 which called (Madina)…you can use any samiliar format number or words with my configuration to understand it.
Can we start now?
Again thank you for help.
scpage Wed, 01/09/2008 - 11:35
Since I am not aware of which ss7path or naspath the new E1 belongs to, I included both as examples. Yes you are using Nailed config based on your trunk file.
First you need to find from your provider the SS7 CIC range for the new E1. I am assuming
CICs 32-63 in this example but you must use what the provider gives you in place
of srctimeslot. Also since you dont't need ss7 link on channel 1, it can be used as
a cic but again you will need to check with your provider.
Below is steps to add additional E1 (non service impacting)...
NAS config:
If E1 is for ss7p-jtc-abdali:
controller E1 7/2
framing NO-CRC4
pri-group timeslots 1-31 nfas_d none nfas_int 1 nfas_group 0
no shut
If E1 is for ss7p-jtc-tlaaali:
controller E1 7/2
framing NO-CRC4
pri-group timeslots 1-31 nfas_d none nfas_int 1 nfas_group 1
no shut
PGW config:
If for ss7p-jtc-abdali...
prov-sync (if you have redundant PGWs)
(will add cics 32-63)
If for ss7p-jtc-tlaaali...
tareqrebhi Sun, 01/13/2008 - 08:51
ok do i need adding the following? :
prov-add:DPC:NAME="dpc-madina",DESC="DPC of madina ",NETADDR="0.21.3",NETIND=3
prov-add:SS7PATH:NAME="ss7p-location 1",DESC="ss7 path to location-1",MDO="ETS_300_356",CUSTGRPID="0000",SIDE="network",DPC="dpc-location-1",OPC="company-opc",M3UAKEY="",ORIGLABEL="",TERMLABEL=""
prov-add:LNKSET:NAME="linkset-madina",DESC="Link Set madina",APC="dpc-madina",PROTO="SS7-ITU",TYPE="IP"
prov-add:SS7ROUTE:NAME="ss7route- madina ",DESC="ss7 route to madina ",OPC="company-opc",DPC="dpc- madina ",LNKSET="linkset- madina ",PRI=1
prov-add:NASPATH:NAME="naspath2- madina ",DESC="Nas Path to AS5400 to madina ",EXTNODE="as5400",MDO="BELL_1268_C2",CUSTGRPID="0000",SIGSLOT=0,SIGPORT=0
prov-add:C7IPLNK:NAME="cs7iplinkto madina ",DESC="cs7 link to madina ",LNKSET="linkset- madina ",SLC=0,PRI=1,TIMESLOT=1,SESSIONSET="cs7set1"
prov-add:IPLNK:NAME="nas-iplink2",DESC="IP link 2 to AS5400",SVC="naspath2- madina ",IPADDR="IP_Addr1",PORT=3003,PEERADDR="",PEERPORT=3003,PRI=1,IPROUTE=""
scpage Mon, 01/14/2008 - 11:13
Yes, if you are adding a new DPC and want to associate the new E1 with the new DPC.
tareqrebhi Tue, 01/15/2008 - 00:59
Dear i appreciate your help so much i think now we arrived the final points so i f you can Bears me?
Just please any advice for commands starting configuration, any sequence to follow it to put commands and if i my service come down what i should to re-back the previous configuration?
tareqrebhi Tue, 01/15/2008 - 02:55
do i need like this command:
or this just for editing?
thank you.
scpage Tue, 01/15/2008 - 08:21
Correct, you only need numan-ed if you are editing a dialplan entry. You would not need this command when just adding an additional e1.
tareqrebhi Sun, 01/13/2008 - 09:10
if i add at PGW new command for existing E1 configuration and discovered this command not correct can simply remove that command and the service then back to work again?
if there are steps to do this work can you advice me?
thank a lot.
scpage Tue, 01/15/2008 - 08:33
Once the config is deployed, you can simply remove the config applied in reverse order using
For example:
prov-dlt:naspath:name="naspath2- madina"
Or you can use config-lib to change back to previous config. However you must take an outage. Login as mgcusr,
The Configuration File Library Main Menu
1. List Configuration Versions in Library
2. Save Production to a new Library Version
3. Copy Library Version to Production
4. Remove Configuration Library Version
Enter Selection or 'q' to quit>
Select Option 3, choose the last known working config.
tareqrebhi Wed, 01/23/2008 - 01:47
what commands should use at NAS to limit carrier's calls or let say Voice traffic?
can give example please?
thank you...
scpage Wed, 01/23/2008 - 15:07
tareqrebhi Thu, 01/24/2008 - 01:11
it is very useful doc. but it didn't solve my problem.
that i need following example:
carrier 1 (IP is just to use only 10 chanels from my first E1.
carrier 2 (IP is just to use only 10 chanels from my first E1.
did you get my point?
i saw in this doc :
this example with title (Applying Call Limiting to an MGCP Gateway ):
i see IP addrress , can i use thi example for my case?
thank you.
tareqrebhi Thu, 01/24/2008 - 09:20
i need to configure IVR at AS5400 i did :
call application voice TCLware.1.2.3 tftp:// 1
call application voice TCLware.1.2.3 language 1 en
call application voice TCLware.1.2.3 uid-len 8
call application voice TCLware.1.2.3 pin-len 6
call application voice TCLware.1.2.3 set-location en 0 tftp://
but when i put application TCLware.1.2.3 the calls for outbound are not pass.
any help?
tareqrebhi Tue, 01/15/2008 - 08:19
this command is not acceptable at NAS:
rule 1 /\(^63\)/ /962\1/
Incorrect format for Translation Match Pattern
any help?
scpage Tue, 01/15/2008 - 08:43
Please send show ver from nas and the output of this when you paste it in your NAS:
conf t
voice translation-rule 1
tareqrebhi Sun, 01/20/2008 - 00:16
Dear thank you much for your helping .
Now i am following our talking i will give the feed back for the results you are great.
scpage Mon, 12/03/2007 - 13:33
You can export the config using the following command via mml:
Once the command has completed..exit mml
cd /opt/CiscoMGC/etc/cust_specific/yourdirnamehere
The files in that directory contain your config...viewable as text.
tareqrebhi Tue, 01/08/2008 - 06:28
Thank you for your help.
i have this question, My AS5400 send CDR for my Billing System ... but the calls or CDR for incoming national calls (Mobile & Fix)to my network are coming without prefix for our local and national calls which is 00962, on other hand calls from my network to other local carriers include the prefix it clear?
All other International calls include correct prefixes no problem.
Local Mobile= 0777223344
Local Fix= 064536543
my network= 063000000
Jordan Prefix= 962
Now call from o777223344 or 064536543
to 063000000 has the error where CDR at Billing system without 00962 it is only 063000000 it is not 96263000000 this take us that call comes from Phillipines Fix 63 and not from my network 63000000.
Remember calls from 063000000 to any destination is right prefix.
any help please at AS5400 or PGW2200??
