MLPPP urgent
Nov 18th, 2007
Hi All,
One of my client has raised a requirement of bundling 2xSTM-1s to achieve the throughput of more than 150Mbps.
Please suggest, if MLPPP can be workedout on POS (OC-3 interfaces).
Its an Cisco-GSR and Juniper Interoperablity case.
Paolo Bevilacqua Sun, 11/18/2007 - 11:34
  • Hall of Fame,
    Founding Member
Yes, for example a SIP-400 would support that, even for oc-48 interfaces.
gaurav_thapar79 Sun, 11/18/2007 - 11:48
As per your post, i can have MLPPP bundle of 2xSTM-1 or 2xOC-3 interfaces and can achieve throughput more than 250Mbps on bundle.
Cld you please share the modules and router IOS versions to support this.
Would appreciate if you can share the URL also for a ready reference.
