VLANs over wireless
Nov 18th, 2007
I know that Multiple VLANs on a segment need a trunk link to transfer traffic to another switch.
BUT, can I configure a switch connected to a wireless bridge to transfer VLAN tagged frames through the wireless bridge?
I would think that if the encapsulation sets up, then the frames will not be stripped of their VLAN tags on the other end.
Thoughts?
colin.mccrory Sun, 11/18/2007 - 15:49
There is a way to configure VLANs to be transported across a wireless bridge.
You extend VLANs into a wireless LAN by adding IEEE 802.11Q tag awareness to the bridge. VLAN 802.1Q trunking is supported between root and non-root bridges through the bridges' primary SSID.
Please check the following link on CCO on how to achieve this on 1400 series bridges.
http://www.cisco.com/en/US/partner/docs/wireless/bridge/1400/12.2_15_JA/configuration/guide/p15vlan.html
Colin
Ericunicast Sun, 11/18/2007 - 18:50
Thanks for the input.
Is there anything other than the 1400 series bridges that I could use to accomplish this?
