SRST with fractional ISDN CUCMBE 6
Answered Question
Nov 18th, 2007
I am carrying out an install with CallManager 6 Business edition and run into a hurdle.
As the customer only has 15 Channels on the ISDN30 E1, I have shut down the channels using the maintenance option in the advance tab of the system parameters; this works fine when the gateway is in MGCP mode. The problem I have is when the gateway falls into SRST mode, as it attempts to put the outbound call out on channel 30 and therefore the call fails. Does anyone know of a fix for this.
Correct Answer by gogasca about 9 years 8 months ago
Use under the ISDN interface the
"isdn b-channel ascending" command
Overall Rating: 5 (1 ratings)
vmoopeung Fri, 11/23/2007 - 12:00
  • Bronze, 100 points or more
MGCP fractional T1 is not fully support in Cisco callmanager , better try changing to H.323 gateway for fractional T1.
Correct Answer
gogasca Sat, 11/24/2007 - 00:55
  • Green, 3000 points or more
