11-18-2007 02:15 PM - edited 03-05-2019 07:29 PM
Can anyone please advice what logging level is required to log the port interface state (going up or down) on the cat6500 and 4500 switch?
TIA
PF
Solved! Go to Solution.
11-19-2007 05:34 PM
According to the link I posted, the global option is only allowed in the SX code which is the 6500/7600 line.
For the 4500, you will have to go with the interface level.
The command should be applied on the physical interface, the port-channel is a logical interface.
11-18-2007 04:27 PM
6500 and 4500 switches do not log these kind of events like the 3560 and 3750 do.
It has nothing to do with the logging level but a logging option on itself.
The command can be executed at interface level or global.
logging event link-status
11-19-2007 03:54 PM
Edison,
Thanks very much for the reply. On the 4500, it can only be applied per interface. Maybe it is the version we are using 12.2(25)EWA8. We have a couple of etherchannels configured. Should the command be applied on the port interface or the port-channel?
TIA
PF
11-19-2007 05:34 PM
11-19-2007 08:35 PM
Thanks heaps. Fully understand.
PF
03-05-2008 09:59 AM
This post was very helpful. FYI, On my 12.2(31)SGA1 code of my 4507 with SupV-10GE, I was able to apply it globally.
