Switch info required
Nov 18th, 2007
Switch with 24 10/100 ports + 2 GB Ethernet ports, what will be the maximum through put in mbps at any point of time?
What is the suggested switch which could handle around 2GB data at any point of time?
is there any way to convert mpps to mbps?
Pavel Bykov Mon, 11/19/2007 - 00:03
  • Silver, 250 points or more
There is no normal way to convert mpps to mbps, since packets can have different sizes.
Rule of thumb is to multiply MPPS by 1000, which would correspond to 125 byte packet.
The switch you are looking for is 2960, the WS-C2960-24TC-L
Hope this helps.
Please rate all helpful posts.
shiva_ial Mon, 11/19/2007 - 04:09
may be etherchannel configuration
if i have understand ur question properly
sarfaraz1981 Mon, 11/19/2007 - 21:55
hi
if u wnat to have 2 gb throug put, its better to configure ether channel on the switch .
