ccme and inbound calls
Nov 18th, 2007
With call manager, you can receive up to 200 calls before you receive the busy signal on a 7941/7961 phone.
It is not clear to me how many inbound calls you can receive with ccme on a 7941/7961. It look like only two but could someone confirm
Many thanks
TT
craiglcve Sun, 11/18/2007 - 19:05
There is no max call or busy trigger parameters on CME like there are on CallManager. When you use the ephone-dn command you have the option to specify it as a dual line phone that gives you a second channel for transferring, conferencing, Call waiting, etc. You can do things like shared lines or extension overlays on multiple phones for call coverage. But in a nutshell you are correct, a line is limited to two calls unless you use other types of configurations for call coverage.
Ephone-DN Command
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucme/command/reference/cme_e1ht.html#wp1056194
CME Command reference
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucme/command/reference/cme_cr.html
RICHARD MESSINGER Wed, 01/16/2008 - 07:59
To get around this limitation, if I have a 7960 phone, can I have the call roll to a second phone number that appears on another line? User wants to somehow not go to the auto attendant unless absolutely necessary.
Paolo Bevilacqua Wed, 01/16/2008 - 08:06
preamble, "auto attendant" is better, as anyone dealing with more that two calls at once will easily realize.
This said, you don't need to divert to another number, but to another ephone-dn. This can have the same number, lessere preference, and be sent there by CFB from the preceededing ephone-dn.
Usually ephone-dn with this chained config are put in overlay with the "c" separato on a single button.
