Failed to access ACS SE console after bootup
Nov 18th, 2007
I set the baud rate to 115200, when ACS SE bootup it display the bootup message, I failed to console in using the same baud rate after ACS SE fully bootup.
I had try all the baud rate setting but failed to access through console.
What could be the problem, console port failure or the setting on ACS SE?
regards,
Sam
Jagdeep Gambhir Mon, 11/19/2007 - 13:56
Is it a new appliance ? What is the message you get on console during boot up ? Ia it happening after configuring initial setup and reload ?
~JG
ccsam Wed, 11/21/2007 - 19:31
Hi JG,
It's production unit where I can access using GUI.
When I reboot the ACS SE, I can see the bootup message from the console using 115200.
After fully boot up, the console port cannot be access even though I can the baud rate to all other setting.
