Traffic rate for VPN traffic on Cisco PIX 535
JORGE RODRIGUEZ Sun, 11/18/2007 - 19:25
Gilbert, you posted a good question.. one that would like to do myself as well, I normally monitor PIX outside interface off our external switch using PRTG but this is just overall port utilization but nothing to brake down what type of traffic is mostly used.
You can try monitoring Ipsec L2l traffic by graphing it through PDM 6.x or ASDM if you have 7.x and get an overall tunel or tunels utilization graphs but eventually you may need to do some basic math by comparing average outside interface utilization and comparing L2L tunnels graphs traffic utilization.
When you load PDM or ASDM there should be a monitoring tab , go there and you will see the types of graphs you may use yo collect data from, IPsec Tunnels is one of them.
Jorge
