PSTN simulator
Answered Question
Nov 18th, 2007
How do I make a PSTN simulator to use in my voice lab?
Correct Answer by ellis_b about 8 years 9 months ago
Yup. We have a 7960 plugged into each of our PSTN simulators. :)
Yes, that PSTN config uses CME.
I tried to post the config in here, but it wont let me due to size limitations. Here's a link to the PSTN config we use.
http://www.ccbootcamp.com/download/!Voice/Files-For-NLIs-CCIE-Voice-Lab-Workbook/base-configs/PSTN-v3.txt
(watch the word wrap)
The dial plan for this PSTN config is in here:
http://www.ccbootcamp.com/download/!Voice/voice-rack-access-faq-v2-6.pdf
enjoy.
-brad
Steve,
You could use a 3640, 3700 series, 2800 series router, etc. Any router which will take voice modules should work. If you use a 3640 or 3700 series router, you will need NM-HDVs with PVDMs on them. If you use a 2800 or 3800 series router, you'll need PVDM2s on the mother board.
I use a Cisco 2811 router with the following modules:
VWIC-2MFT-T1
VWIC-2MFT-E1
VIC2-2FXO
VIC2-2FXS
NM-4A/S
Don't forget about the PVDM2s so the router will recognize the voice modules. I have the NM-4A/S in there so that this PSTN simulator can also act as the frame-relay switch simulator. It's a great combo.
thanks,
Brad Ellis
CCIE#5796 (R&S / Security)
CCSI# 30482
CEO / President
CCBOOTCAMP - A Cisco Sponsored Organization (SO)
Email: brad AT ccbootcamp.com
Toll Free: 877-654-2243
Direct: +1-702-968-5100 = Outside the USA
FAX: +1-702-446-8012
YES! We take Cisco Learning Credits!
Training And Remote Racks: http://www.ccbootcamp.com
Overall Rating: 5 (8 ratings)
Correct Answer
ellis_b Sun, 11/18/2007 - 19:12
Steve,
VWIC-2MFT-T1
VWIC-2MFT-E1
VIC2-2FXO
VIC2-2FXS
NM-4A/S
thanks,
Brad Ellis
CCSI# 30482
CEO / President
SteveDexter Sun, 11/18/2007 - 19:13
Sweet! That's what I am looking for. Do you have a configuration for the PSTN simulator you are using?
Correct Answer
ellis_b Sun, 11/18/2007 - 19:16
enjoy.
-brad
SteveDexter Sun, 11/18/2007 - 19:21
It looks like you are using CME is that true?
I'll give it a try after I purchase a router.
SteveDexter Sun, 11/18/2007 - 19:50
That makes sense. It looks like I will need a 7960 phone as well. Is this correct?
Correct Answer
ellis_b Sun, 11/18/2007 - 19:53
