point client to specific access point
Nov 18th, 2007
Hi NetPro,
does anyone knows how / what command use for AP setting. which means i want this user only associate with specific AP only.
i am using Cisco Aironet 1200 series.
your reply will be higly appreciated.
regards,
Jackal
Overall Rating: 4 (2 ratings)
bbxie Mon, 11/19/2007 - 16:54
  • Silver, 250 points or more
You can use MAC address ACLs to block or allow association to the access point.
AP(config)#access-list access-list-number
{deny | permit} source [source-wildcard]
AP(config)#dot11 association access-list access-list-number
ney25 Mon, 11/19/2007 - 17:42
Hi BBxie,
thanks for reply, your reply very helpful.
here with another question which i am in doubt.
now, i am sitting in the room and inside the room only 1 Access Point which 3 - 5 meters away for me. but i dont understand why i cant associate to this access point , my laptop always surf by another access point which out of the room and either further than the ap in the room.
what do you think ? anyone can explain to me ... your reply will be highly appreciated.
regards,
Jackal
bbxie Mon, 11/19/2007 - 21:16
there's many possibilities,you should provide more detailed information about your environment, for example: AP model/firmware version, laptop model/OS/wirless card driver, parameters configured in the AP and laptop.
Typically there're some possible reasons:
1. laptop wirless driver bug or compatibility issue with AP
2. No matter what reasons, if your laptop had already associated to the outside AP(for example, inside AP powered up later; there's some time, the inside AP lost connection to laptop), if the outside AP's signal had not dropped to a very poor strength level(roaming threshold), your laptop will not roam to a better signal inside AP
john.preves Mon, 11/19/2007 - 21:22
if you only want to associate to one AP such as performing a site survey, then change the ssid.
when you do this perform a site survey to fix problem 2
