How do I configure different levels of access on ASA?
Answered Question
Nov 18th, 2007
I want to limit access for branch personnel to prevent them from changing configuration on Catalyst Switches, Routers and an ASA Firewall.
For Switches and Firewalls, I configured usernames with Privilege 7 and enabled local authentication (login local).
How do I do this on the ASA?
Correct Answer by kagodfrey about 9 years 5 months ago
You can configure privilege levels on the ASA through the AAA configuration. Take a look at:
http://www.cisco.com/en/US/docs/security/asa/asa72/asdm52/user/guide/devaccss.html
Kev
Overall Rating: 5 (1 ratings)
