%IDMGR-3-INVALID_ID: bad id in id_delete (bad id) - What does it mean?
Nov 18th, 2007
I searched on CCO and all it says LOG a TAC case. Can someone explain what this error message means?
Router is a Cisco 3745 running c3745-ipbase-mz.123-14.T1.bin.
More information can be found in the attached file.
lgijssel Mon, 11/19/2007 - 00:32
Traceback messages like here are almost always an indication of problems within the IOS. For your case, 123-14.T1 is a deferred release Please try upgrading to a newer release before going through the burden of opening a TAC-case.
Suggested release: 123-14.T7(ED)
Justin Reeve Wed, 09/01/2010 - 00:30
Looks like this Bug:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
CSCeh49462 Bug Details
Traceback at id_delete
Symptoms: Tracebacks are generated on a Cisco router that is configured for
analog and digital bulk calls. The error message is as follows
Conditions: This symptom is observed on a Cisco router that functions under stress.
Workaround: There is no workaround.
