CDP
Nov 18th, 2007
If i have L2-switch connect with trunk (permit all vlan) to L3-switch (have three-SVI), when i show cdp neighbor or neighbor detail on L2-switch i will see the three ip address of SVI neighbor L3-switch ?
Overall Rating: 4 (2 ratings)
mahmoodmkl Sun, 11/18/2007 - 22:27
  • Gold, 750 points or more
U will see the ip address of the SVI which is u r management Vlan.
Mahmood
guruprasadr Sun, 11/18/2007 - 22:50
HI,
Each SVI (Switched Virtual Interfac) will have one Management IP Address.
Do check your configuraiton for SVI ?
Pls Rate if HELPS
Best Regards,
Guru Prasad R
