ACS server
Nov 18th, 2007
i have configured the network device group and assigned some dummy entries of acs servers have been added. now what i exactly want is, i want to remove the unnecessary entries in NDG ans also which are added in "Not assigned group". because i am adding secondary server and ofcourse there is auditing, they will ask why did i added that unnecessary entries. so please help me to resolve this issue.
somishra Mon, 11/19/2007 - 00:52
  • Cisco Employee,
Hey Suresh,
Goto Network Config - Select the ACS server entry in the NDG or the AAA clients entry in the Not Assigned Group (the entries you want to remove)and delete the entry.
Rgs,
somishra
psureshrao Mon, 11/19/2007 - 19:06
There is no delete option, only submit, submit+apply and cancel options are there. Atleast there is no option to edit the name of ACS server.
somishra Wed, 11/21/2007 - 02:06
  • Cisco Employee,
Is it ACS for Windows or Appliance ?
psureshrao Wed, 11/21/2007 - 02:55
Its ACS software 4.1.1 build 23 for windows.
Thanks for your support on this.
somishra Wed, 11/21/2007 - 04:04
  • Cisco Employee,
hi suresh,
The ACS database might be having corruption issue. I would suggest you try to compact the database via the CSUtil in the ACS server. This would compact the database and clean the database if there would be any minor data corruption in the database.
1) On the ACS Server open an MS DOS command prompt and change directories to C:\Program Files\CiscoSecure ACS v4.1\bin
2) Type "net stop csauth" and press enter
3) Type " CSUtil.exe -d -n -l " and press enter
4) For each confirmation prompt that appears, type Y and press Enter.
5) Type " net start csauth " and press enter
Compacting the CiscoSecure user database requires that you stop the CSAuth service. While CSAuth is stopped, no users are authenticated
The steps for Compacting the CiscoSecure User Database is given in the following document:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/user/A_CSUtil.html#wp364964
Try deleting the server entry after cleaning the database.
rgds,
somishra
psureshrao Thu, 11/22/2007 - 20:47
Any suggestions?
I thnk my software is corrupted isn't it.
hwknight53 Tue, 11/27/2007 - 04:55
I think that you must put the ACS server in a named group, then go back to Network Configuration, select the group, select the ACS Server, then Delete. You cannot do this from "Not Assigned".
Wes
kalvasaipavan Tue, 11/27/2007 - 06:17
I simulated the above scenario, where i created group and added the servers to that group, when i deleted the group automatically the servers are moving to not assigned group.
it did not worked.
hwknight53 Tue, 11/27/2007 - 06:52
After you select the group, delete the servers, not the group. After the servers have been deleted, then you can delete the group. However, I'm not sure about this.
Wes
psureshrao Tue, 11/27/2007 - 07:07
thanks for your reply, I have tried the same, can you please check for the attachment in this chain. i am not getting the delete option.
Mick O'Donovan Wed, 07/07/2010 - 09:19
Hi all,
Just wondering if a fix was ever found for this or if someone opened a TAC on it? I'm having a very similar problem with an old ACS server I'm running. All the AAA clients are assigned to the "Not Assigned" group and I am unable to end this group to make any changes to possibly corrupt entries (maybe the whole group is corrupt).
Every time I try to click on the link to bring me into the Not assigned group I get "Action Cancelled" error pages in IE. I would very much appreciate a "quick fix" to this problem without having to rebuild my database or ACS installation.
Thanks in advance,
MickoD
