IPCC Documents
Nov 19th, 2007
Hi List;
I found a good link for IPCC documents but most of links are not working inside it, also it is for release 6 while I need something for release 7.
The link is:
http://www.cisco.com/iam/unified/ipcc601/Component_Installation_and_Configuration_Guides.htm
Anyone has a link similar to that but it contains a working link to open the documents and it support release 7?
Any Help?
Bilal
bilalghayad Tue, 11/20/2007 - 05:03
Hi Majdi;
Actually I need a link for the Administration, for example, within the link u sent me, then I accessed the below link and then I tried to select the link related to Administration but it gives me that Un Available Page, you can try it by your self.
http://www.cisco.com/univercd/cc/td/doc/product/icm/ipccente/ipcc50d/index.htm
I am not able to find an administration documentation.
Bilal
