Router 1841 failover
Nov 19th, 2007
Dear All,
I had router 1841 and i want configure failover( i had 2 ISP).
could you advice me and give some documentation ?
i cannot find document.
Best Regards,
Overall Rating: 4 (2 ratings)
guruprasadr Mon, 11/19/2007 - 02:22
HI Rechard, [Pls Rate if HELPS]
Failover configuration is based on how you connect your ISP.
By static Routes means:
>>You can configure the Floating Static Router by varying the AD values.
ip route xx.xx.xx.xx
ip route xx.xx.xx.xx 200
By Protocol Means:
Eg: OSPF - You can vary by means of COST Factor.
We could help if you can provide more information on your requirement.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
rechard_david Mon, 11/19/2007 - 02:43
Dear All ,
Thank you for you advice.
when i have any problem i will let you know.
Best Regards,
