N-Hop as Remote Portlet ?
Answered Question
Overall Rating: 5 (1 ratings)
Ahh its an undocument feature! It threw me for a loop too.
What you need to do is log directly into the server which has campus installed on it and then add the potelet to that public space.
Whats strange is that it appears that the CW assistant workflow calls and displays it remotely from the Master from slaves corretly, but the Iframe can't touch it when you try and add it on the Master public space.
dainat-bis Mon, 11/19/2007 - 07:05
On the slave Campus Manager Server I can add this portlet in the public view, but if I login into the master server this portlet is not accessible.
