AW Client Installation
Answered Question
Nov 19th, 2007
Hi all,
I'm going to install an AW client. Is it mandatory to install it on a machine which belong to the IPCC domain? Or can I use machine in other domain/workgroup?
Correct Answer by antonio.vazquez about 9 years 5 months ago
you can install AW client in another domain while you've enabled trusted domains between both domains.
If you think that post interesting, please rate it.
Antonio
Overall Rating: 4 (1 ratings)
Correct Answer
antonio.vazquez Mon, 11/19/2007 - 02:05
  • Bronze, 100 points or more
Antonio
