Remote VPN Client for EzVPN
Nov 19th, 2007
I have configured EzVPN server on the asa 5520 firewall, which is connected to 3 871 security routers as remote clients. i need to give access to the mobile laptops through the Cisco VPN client software. what configurations i need to add at the server in order for me to use Remote VPN.
Overall Rating: 1 (2 ratings)
aghaznavi Fri, 11/23/2007 - 12:13
In order to access a server that is located in a security Zone from a network behind any other interface, the nat command and the access-list command must be configured.
If the traffic is generated from a higher security interface, configure dynamic nat commands, but if the traffic comes from a lower security interface to a higher security interface, the static nat commands must be configured.
