EzVPN Server & 1721
Nov 19th, 2007
I'm trying to set up an ezvpn server on a 1721 router. I've used SDM to configure the router which has given me the attached running-config.
I'm using Cisco VPN client on windows to try and connect with no luck. I've attached a copy of the isakmp debug which seems to be my first sticking point. Can anyone explain what is happening in simple terms....
dradhika Thu, 11/22/2007 - 23:37
The ezvpn server config seems to be correct.
In the VPN client the password you gave seems to be wrong as per the logs.
1. Can you check if you gave the correct password?
2. If the password is correct, is there any other crypto cli on the router and not in startup-config. If there is any unnecessary cli then try removing and connect. I got similar error when I had other crypto cli. After I removed all them vpn client connection was successful.
