1300 Bridge VLAN support
Nov 19th, 2007
Dears
i have two sites required to be connected using wireless 1300 bridge but There is 30 VLAN and i think that 1300 series support 16 VLAN only is it right ?. Please advice me if 1300 support more than 16 VLAN how to conigure it if not support then which mode support more VLANS.
drolemc Fri, 11/23/2007 - 12:17
You can configure up to 16 SSIDs on your access point/bridge, so you can support up to 16 VLANs. You can assign only one SSID to a VLAN. So it means that you cannot configure 30 VLANs with your 1300 bridge.
Richard Atkin Sat, 11/24/2007 - 00:05
buy a pair of routers, and use the 1300's to provide the link between the routed interfaces, then you only have to pass one VLAN between them.
Then, if you're still desperate to get those specific VLANs to the other site, I believe you can do some magic with your routers to tunnel them inside your routed link.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
