10 GB Etherchannel
Nov 19th, 2007
We have a 4507 switch with redundant supII-plus-10GE with 10Gbase-LR gbics and we are connected via single mode fiber to a 6509 with redundant SUP32-10GE with 10gb-LR gbics. The two active supervisors are connected at 10 gb, I would like to add a 10 gb connection to the redundant supervisors using an etherchannel for added speed and failover. I used the following configs but the lines would go err-disabled. Any help would be greatly appreciated.
Cat 4507 running 12.2(31)SG, RELEASE SOFTWARE (fc2)
interface Port-channel8
switchport
switchport mode trunk
interface TenGigabitEthernet1/1
switchport nonegotiate
channel-group 9 mode on
interface TenGigabitEthernet2/1
Cat 6509 running CATOS NmpSW: 8.4(5)
#module 5 : 3-port 10000BaseGX Supervisor
set port trap 5/1-3 enable
set trunk 5/1 nonegotiate dot1q 1-4094
set port channel 5/1 mode on
#module 6 : 3-port 10000BaseGX Supervisor
set port trap 6/1-3 enable
set trunk 6/1 nonegotiate dot1q 1-4094
set port channel 6/1 mode on
101pch382 Mon, 11/19/2007 - 07:37
I mistyped the config on the 4507 the port channel interface should be 9 not 8.
