Secure ACS redundancy
Answered Question
Nov 19th, 2007
Hi;
What happens if my only ACS goes down? ACS is active on my access switches.
Correct Answer by ardica about 9 years 7 months ago
What deployment scenario are we talking about here? For example, with 802.1X deployments there is a feature (called Inaccessible Authentication Bypass) that allows you to provide access to a specific VLAN in the scenario where connectivity to the ACS server is compromised. Is that something may help you?
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Mon, 11/19/2007 - 08:49
  • Red, 2250 points or more
Request will go to secondary acs. If switch tries to authenticate , request first goes to primary acs, but if there is no response from that acs, switch will send that request to secondary acs.
~JG
Do rate helpful posts
Correct Answer
ardica Tue, 11/20/2007 - 07:02
  • Cisco Employee,
