2 LAN's on a Cisco 877 possible
Nov 19th, 2007
Hi, I'm not sure if this is possible, but I have a Cisco 877 in a remote office that is setup as a VPN our head office. At the remote site where the 887 is there is a another LAN that we want the remote office to use, but this remote office's 2nd LAN can't connect to the VPN, possible? There are 3 spare FE ports on the back can the other LAN plug into that somehow and be segmented to only use that local LAN?
Paolo Bevilacqua Mon, 11/19/2007 - 10:04
If you have an "advaced ip service" image you can configure vlans and assign an own port for that.
Else you can only configure the additional sybnest as "secondary" under VLAN 1 and connect to any port you want.
whiteford Mon, 11/19/2007 - 10:44
Thanks, how would I configure the sybnest as secondary?
I suppose routing would stop the traffic going over the VPN as this other LAN cannot have access.
Paolo Bevilacqua Mon, 11/19/2007 - 13:27
interface XXX
ip address secondary.
If the crypto map is configured to build a security association for that network too, it will be sent over VPN. Routing doesn't have a direct role in that.
