Router(boot) ... issue after upgrade....
uubozou11
I have a uBR7100 and after the IOS upgrade last week whenever it reboots I would get the prompt of 'router(boot)'...after some troubleshooting it was decided by someone else that I had a bad image file, to get a different one. I did that this weekend and after the upgrade this morning, was greeted yet again by the 'Router(boot)' prompt. What causes the prompt to show this?
Thanks..........
2 Accepted Solutions
Jimmy
With all due respect, I do believe that you are wrong. The flash card is not in slot 1. Please look at the 7100 and confirm what is in slot 1.
And I believe that this message (as I have indicated before) shows that the flash card is recognized and is ok:
47040K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
Rick
Rick
You still are not running the correct image , (disk0:c7100-ik9s-mz.123-12e.bin) you have an image for a 7100 vpn router and you have a ubr7100 , not the same . You have 2 threads for the same problem in here. Until you get the correct image it won't boot. I'm not sure the ubr supports SSH or not the images do not indicate they do but i could be wrong . In any event the image has to look like this, the one you have now is not correct. I did not see any K9 images for this device.
ubr7100-ik8su2-mz.123-21a.BC4.bin
15 Replies 15
Richard Burts
Jimmy
There are a couple of things that might cause the router to boot and wind up in router(boot). One possibility is that the configuration register has been set to cause this. It is more likely that this is caused by the router not being able to find a valid image to boot. When you were loading the new image file did you delete the old image from the router?
It would be helpful if you would boot the router again and capture the console messages as it boots and post the console messages. This would give us the most accurate identification of the problem.
Rick
Rick
Thank you for your help! There was a small issue (see Router suck in boot mode....http://www.cisco.com/warp/public/108/hwts_71xx_23240.html)
but following those steps didnt help me either.
I have attached the output of the commands....
And I have also already formatted disk0 and ram confreg/reset but neither helped.
And finally, did this one also...
http://cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
Steps worked, but still boots into (boot) mode.
Thx
a senior engr here was giving me the wrong file, ...he was giving me the image file, not the full version. Thanks to those who responded....but now with the full version on there, I get...
Buffered messages:
Queued messages:
*Nov 19 01:38:45.107: %PA-4-PCIVALID: PCI activation failed, bay 2, 0x1119DC04
*Nov 19 01:38:45.107: %PA-3-DEACTIVATED: port adapter in bay [2] powered off.
*Nov 19 01:38:45.107: %PA-3-IMPROPER_INSERT: Improper insertion for slot 2. Remove and then re-insert the PA
*Nov 19 01:38:46.891: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 585)) is not supported on this image.
Please issue "show diag" in fully loaded IOS image
to get the PA's information and verify if it is supported
by this image, a newer version may be needed.
*Nov 19 01:38:46.891: %PA-3-DEACTIVATED: port adapter in bay [1] powered off.
TLB (load or instruction fetch) exception, CPU signal 22, PC = 0x606B8BB4
Translated, does that mean slot1 (disk0) is not supported by this IOS version?
Do a "show version" and post here .
IOS (tm) EGR Software (UBR7100-BOOT-M), Version 12.3(21a)BC3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Thu 26-Jul-07 17:00 by alnguyen
Image text-base: 0x60008EB8, data-base: 0x60B6A000
ROM: System Bootstrap, Version 12.0(5r)XE2, RELEASE SOFTWARE (fc1)
Router uptime is 17 hours, 44 minutes
System returned to ROM by error - an Error Interrupt, PC 0x606E19EC at 02:09:34 UTC Mon Nov 19 2007
System image file is "bootflash:ubr7100-boot-mz.123-21a.BC3.bin"
cisco uBR7114 (EGR) processor (revision A) with 122880K/73728K bytes of memory.
Processor board ID 31256715
R527x CPU at 225MHz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
125K bytes of non-volatile configuration memory.
8192K bytes of Flash internal SIMM (Sector size 256K).
Jimmy
Thanks for posting the output of show version. It shows clearly that you are still running the bootloader code and not the full image:
I think I understand from your earlier post that you now have a valid image file on the router. But it is not booting. Am I correct in assuming that the only boot system command that you have in your config is the one that points to bootflash? If that is the case then you need to confirm the location and the name of the full image file and then to configure a boot system command that will point to that image file.
Rick
Rick
What happens is that it boots, starts to load the full image, gets the error about the PC Card not being compatible, reboots, then falls back to the (boot) file. So, ultimately whenever I try to use the new IOS (supporting ssh) its barfs (
via the sh run line of boot system flash disk0:c7100-ik9s-mz.123-12e.bin), then falls back to the boot file (which atleast gives it some functionality). I have opened up a case with TAC and am awaiting their response.
Jimmy
Perhaps I am mistaken, but I do not believe that the error message you saw during boot was related to the PC card. The error was about something in slot 2 and I do not believe that the PC card is in slot 2.
Also there is this message from the show version:
which tells me that the PC card is functional. It will be interesting to see what the TAC says about this.
Rick
Rick
Thanks for your input...
Per this error....
I assumed it was talking about the 48 MB flash card. But I could be wrong...
Jimmy
Rick
Rick
I re-read your response, I see now...we are loading a image for a VPN router, we have a uBR. ...duh! Thanks, will look into this... :)
Well, with everyones help, I finally sludged through and got the right IOS on there. The first three files given to me were wrong (two were boot files, one was for a 7100 VPN router, not a uBR). I got ahold of Cisco, they hooked me up with the right file, and amazing, it installed perfectly. Thank you to all that responded, and we can close this case :)
Happy Thanksgiving!!
