CSV file Header for "Switch"
Nov 19th, 2007
I have several hundred users I need to subscribe to Unity but need them to be on a specific switch (PIMG)
I cannot find a header to use in the CSV file to set this.
Any help is appreciated
navinger Mon, 11/19/2007 - 11:13
  • Bronze, 100 points or more
You can specify the switch on the subscriber template used to import the subscribers. In Cisco Unity Bulk Import (CUBI), you select a subscriber template to use, but you can override that by including the "SUBSCRIBER_TEMPLATE" column in the CSV file.
Nancy
